Chimneys for factory built fireplaces
I have a new masonry chimney with an 8″ clay flu liner. Is anyone aware of a manufacturer of a factory built wood burning fireplace with specifications that allow for direct connection from the flu box to the masonry chimney. The chimney chase is insulated. Access to the chimney is maintained.
Do you mean a woodstove with front doors/clear panels that can look like a fireplace? Or a fireplace-fireplace? If the woodstove, I'd check out vermont castings for starters. There are all sorts of other manufacturers, and opinions which are the best outnumber the manufacturers.
