I dropped a spakle knife into a fiberglass whirpool tub and chipped the bottom fiberglass. Is therea fix I can do or have done to remedy it? Thanks
Do you know the manufacturer?
You can call them, and they'll give you the name of someone to repair the tub.
I found that out the hard way, too. Except I dropped a piece of tile. LOL
Never done a tub, but have done boats. It should be pretty similar. The only hard part is matching the gel coat.
Other than that, you just:
sand a little bit around the chip with some 200 grit;
Spread the gel coat into the chip, and surrounding area with a plastic spreader;
cover with shrink wrap, and then press lightly on that with a sponge. The idea is to get a smooth surface.
When the gel coat hardens, then wet sand with 400-grit, and buff it out.
>> Is therea fix I can do or have done to remedy it? <<
Yea - call a tub repair guy. I've got one who would probably charge $50 for that... about 20 minutes....
50.00 bucks, 20 minutes beautiful. thanks
Yea - they come out with a kit of 10 different whites and can mix to match on site too. All kinds of nasty smelling chemicals, and other mysterious stuff etc. A magic wand too. Hardly ever had a repair that could be seen. Your price may vary - the guy I use I give several a year - my subs keep him in business.
Edited 7/29/2008 10:17 pm ET by Matt
