Hello everyone, want to add more light and air to old home made of cinderblocks covered with stucco looking for any ideas for best ways to frame new windows cut out cinder blocks frame with 2×6’s what to look out for?
My experience is limited, but I would put a moisture barrier, such as tar paper or plastic flashing, between the 2 x 6's and the block, and use pressure treated, but dry lumber. If you can't purchase the lumber dry, buy it early and let it sit indoors for a while. You don't want to trap moisture behind a new window, and you want the wood to do most of the warping it's going to do before you use it.
Check the window installation instructions. Most of them say to cut the nailing flange off, so you have to measure and frame accordingly.
a cinder block is 8 inches wide. I used 2x8 on mine
