Does any one have advice on cleaning a cast aluminum barbie; such as oven cleaner then spray off with hose?
Oven cleaner eats aluminum. Washing soda does a pretty good job on burned on gunk, but there's a fair chance it also eats aluminum.
Sandblaster? Unfortunately, the burned on gunk may be tougher than the aluminum.
Long soak in clear water will get a lot of it off, but will also leave a lot.
Personally, I wouldn't worry about it.
you want to clean your bbq? wont that get rid of all of the good falvor you have put into it?
james
Brinkman for president........who said that again? The Blodgett kid???????
Does any one have advice on cleaning a cast aluminum barbie; such as oven cleaner then spray off with hose?"
Howard,
Pressure washer, but from your question, I guess you don't have one, or you wouldn't be asking. Seriously, they do an awesome job with no cleaners at all.
Jon
Second on the pressure washer- looks like new when done.
Obvious. More steak. And maybe some beer.
Cleaning is for wimps. Just throw a little gasoline on it next time you light it up -- that'll burn off the crud.
Assuming you mean the grille and not the body . . .
Heat the grille, not to very hot, but enough to help loosen some of the bits. Use a brand new grille brush for best results; nylon bristles are probably better for aluminum. Old margarine or spred tub with baking soda mixed with some club soda. Brush that mix on the worst spots & let bubble a bit before scrubbing.
For prevention, oil the grille before use (but after warming). Wad up 3-4 paper towels and spray with cooking spray (or use a bit of vegetable oil), grab that in your grille tongs and wipe the grille before throwing the food down. Not a bad idea to give a wipe or two on a new grille every time it's heated, starting out--grilles will "season" with age.
My BBQ expert BIL uses a wire brush followed by wet paper towels as you suggest.
-- J.S.
uses a wire brush
That's what I use, but my Weber grille has a stainless grille, so, I'm not worried about scratching it with a brass bristle brush.
I put a paper towel holder up under the patio cover near the grille, just to have them handy. Best thing I ever did.Occupational hazard of my occupation not being around (sorry Bubba)
Clean the what? yu from up north ar'ntch ya? (I'm not southern, but I spent some time there and you never, every remove the flavorin' from the bar-b-q).
