I’m looking for suggestions on how to clean tile and grout. My wife insists that the best method she found was using muriatic acid and water. I know that’s not safe and a flooring rep. once told me it’s not good for the grout. Please advise.
Also I had read an article in fine homebuiding about a wood floor installer in Florida I believe his business was in Sarasota please advise which issue it was and what the name of the business owner and email address is. I am going to install a engineered wood floor over concrete and I’m looking for advise.
Thanx in advance
Greetings guillaume,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
As for your grouting question, if you fail to receive the needed data on Breaktime, here is a link to a ceramic tile forum that may be able to help you. http://www.johnbridge.com/vbulletin/index.php
Cheers
94969.19 In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
Muriatic will destroy the grout and if the tile is a natural stone, it can etch that as well.
A safe way to clean grout is to use a neutral cleaner like Oxyclean. Mix it at twicw the recommended strength. Scrub it into the grout with a stiff brush and remove the dirty water with a wet vac so you pull the dirt off the grout.
If needed, repeat a second time at normal strength.
