Closet organizer using Festool’s LR32 and DF500 connectors
kevin_edmund | Posted in General Discussion on April 26, 2020 07:36pm
Hi,
I’m not sure if this is the right category, but here’s my problem: I don’t know how to set-up/register the Festool’s KV-LR32 connector and the DF500 without trial and error and/or with shims.
I want to build a closet organizer in a closet with a narrow entrance/door. I figure it would be best to build the organizer with knockdown connectors. Since I have the DF500 and the LR32 already, using Festool’s LR32 to mill 5 mm holes and the KV-LR32 connectors with dominoes would be a good way to keep everything registered for hardware and shelf placement – in theory.
However, there are two points i’m not sure of when using this system: 1) Should I set the 5mm system hole at 9.5mm from the bottom edge of the vertical partition using the 9.5mm linear stop for the LR32 – most ply is actually closer to 18.25mm thick not 19mm (=2*9.5); 2.) How to easily centre a domino mortise on the end of shelf that would be centred on the 5mm hole (without trial and error and shims) at the bottom of the vertical partition and at the large top shelf position.
I thought that the DF500 has a 10mm offset from the bottom shoe to centre-line of bit and using the pivoting fence on th DF500 with the thickness gauge would give 9mm – 18/2).
I was even thinking these tools/systems could be used to install drawer dividers in the organizer after i got the partitions up. If the drawer division doesn’t work out, it would seem easy to change if using knockdown connectors.
I was originally thinking that i would build a  separate “box” for the shelves/drawers and attach it to the vertical partition and the shelf with cabinet connector bolts, but that would require two more plywood side panels. The plywood is expensive but so is time!
The rough sketch, attached, gives you an idea of what i want to get done. The partitions would be supported on stretchers going across the back wall (3/4 x 3″ wide.
  1. kevin_edmund | Apr 28, 2020 06:27pm | #1
    I asked Festool about this and the answer for their "System" was that you would have to use shims. As a helpful suggestion, Festool said that the shim could be any material as long as it is flat ??!!
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
