In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Cold Climate Furnace in the Attic
erk | Posted in Energy, Heating & Insulation on March 7, 2007 09:58am
Hello,
I’m going to start a house this spring that will be a large two-story that calls for having two furnaces and AC units.  One will be in the basement and the other in the attic.
Here in the Midwest, basement units are the norm and I don’t regularly see attic units.  I seem to be getting conflicting answers on several questions that I have, so I was hoping to get some additional input.
1. Should a condensing furnace be put in the attic?  If so, should the equipment be insulated or should it be located in an insulated room?
2.  Even if a condensing furnace is not a good idea, should the 80% furnace be insulated or should it be located in an insulated room?
3.  Is insulated flex ducting or uninsulated sheet metal ductwork better?  Either will end up under the blown cellulose for the attic.
Thanks in advance,
Erk
  1. woodguy99 | Mar 08, 2007 01:40am | #1
    I can't answer your questions other than to say you might consider insulating your rafters instead of the attic floor, that way your ductwork will be in conditioned space which is a good idea.
    Who will be doing your HVAC work?  They should have an engineer or at least somebody experienced enough to help you plan this.
    "This is a process, not an event."--Sphere
  2. DanH | Mar 08, 2007 01:44am | #2
    If put in an unheated space, a condensing furnace must have heater cables added to the condensate trap. Our new condensing furnace came with specific instructions for this. (Of course, if power fails in winter you may end up with the trouble/expense of replacing a cracked trap assembly.)
    The big problem with having a furnace in unheated space is that ductwork is rarely that tightly sealed, and you end up losing a lot of heated air to the attic space and vice-versa. However, if ductwork is VERY CAREFULLY sealed then this shouldn't be a problem.
    Of course, the ductwork also needs to be insulated, both to avoid losing heat in winter and to prevent condensation in the summer, when the AC is running.
  3. IdahoDon | Mar 08, 2007 07:00am | #3
    A common solution is to have an inch of foam sprayed to the underside of the rafters/sheathing to make the attic space semi conditioned.  This also eliminates the need for attic venting.  We did that all the time in a cold spot in Wyoming.
    Flex duct is so quick to run and less prone to create noise that it's what our HVAC guys usually go with unless we're maximizing a small space.
    Good heating
How to Choose Exterior Paint Colors for a Home
For a timeless exterior aesthetic, consider the home, its surroundings, and your personal style.
  • Track Lighting for Functional Ambiance in Busy Spaces
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
