I am looking for colored caulk or ways to color caulk. I saw an article a while back on it if any body can refresh my memory that would be great!
Blues
Blues
To caulk wht...
Pecora has a long line of colored caulks and your locl cabinet supply shop will too...
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
WOW!!! What a Ride!
"I am looking for colored caulk or ways to color caulk."
BluesHound,
One of the myriad of tasks I have to perform where I work is dyeing "stuff" (usually resins).
Virtually all the dye I use are aniline based. Caulking tubes are easily available empty BTW, and I can give you sources.
But depending on how close the match you are looking for.........blending can get very tricky. You can get very close, try to get a tad closer, and boom, overshoot. Then have to resort to dilution...Oh, and some can change color as they cure.
But I know what you mean, just yesterday I blended up some light red oak colored filler for a staircase I'm rebuilding.
The stuff on the right is what I blended, the middle was sold as "light oak", and the stuff at the end as "red oak"
Jon
Edit: I MEANT LEFT not right....That was embarrasing. started off as white.
Edited 5/13/2004 12:59 pm ET by WorkshopJon
See above edit. How come you didn't call me on that one? Geez.
Jon
If you're doing something like a counter, start with latex caulk. If you can start with one which is colored somewhat like you want, you have less work. Squeeze a bunch out on to a board. Color it with universal colorants. These are pigments (in bottles) available in any good paint store, intended to color paint. Add only a few drops at a time and mix thoroughly. You may have to use several pigments to get the effect you want. After you get the correct color, wipe the caulk into your joints. With a wet rag or sponge, tool it like you'd do to grout.
forget where I saw it, but someone makes a re-fillable cailk tube..I often use syringes from a vet..bigguns for cattle and such..lighweight spackle and waterbased tints works like a dream..
"but someone makes a re-fillable cailk tube.."
Sphere,
Not to razzle you, but time IS money to some. Depending on how big a purchase, an empty tube costs anywhere from $2.00 to 25 cents. In this country, with the cost of labor, how could one ever justify cleaning one out?
Sad but true.
Jon
coupla points..a refillable tube may be misleading, maybe a disposable fillable tube..at a buck or two I'd buy a few..
the syringe I had used I dont clean out, just cap it with a wire nut and ele. tape. The mix stays useable for quite awhile..I was doing a staple up cardboard cieling, the 12x12 tiles..had to fill a few face staples and it was an off white..worked like a dream.
I also use the buffalo needles for glue, same deal leave em filled..and cap well.
I should tell the story about a carp. I knew who filled a coworkers glue tube with the coworkers own excrement, that he always deposited in the basement before a pour..while he was at his liquid lunch, this guy took his glue tube and did that. Afthe lunch the guy comes back to subflooring and squirts out a bead,, see's it and says "what the..?' swipes a gob on his finger and SNIFFS it...then puked. Never crapped ina basement again.
so at times it may be worth cleaning one out..
Never used it, but Red Devil is advertizing "Create-A-Color" caulking.
http://www.reddevil.com/products.cfm
