Compressor – Store / use upright?
rwjiudice | Posted in General Discussion on May 1, 2007 07:00am
Looking for opinions: I have a 20 gallon shop sized air compressor. Just an ordinary (not oiled) run of the mill homeowners. I suse it maybe 3-4 times a month…. blow up pool rafts, blow out sprinklers etc. It takes up about 3.5 to 4.0 feet (lengthwise). It has 2 tires on the back end, a rubber footed leg on the front, with a pull handle.
Can I store and use it if I sit it upright (on it’s end).
It would save shop space. But is there some law of the universe that would prohibit usining it that way??
Edited 5/1/2007 12:01 pm ET by rwjiudice
  1. freestate1 | May 01, 2007 08:55pm | #1
    Storing and running it in a vertical position should pose no problems.  However, unless you want to flirt with creating a de facto bomb down the road, you should always let it drain in the horizontal position after use (assuming that the drain valve is on the botttom).
