I just poured a small concrete slab and today I discovered that it has a low spot in the center it’s about 12″ in diameter and 1/4″ or less deep. I am planning on getting some fine mix concrete and leveling up the spot and blending it in with a broom. Will this work? How long should I wait before I attempt this repair? Any better ideas? It won’t kill me just to leave it that way but I would rather it be perfect if that is possible. It was poured yesterday.
Thank for your help
Dan
In issue #314, Fine Homebuilding published an article titled “The End of Deep Energy Retrofits” by Rachel White of Byggmeister. The premise was that deep energy retrofits are not as…
I just poured a small concrete slab and today I discovered that it has a low spot in the center it's about 12" in diameter and 1/4" or less deep. I am planning on getting some fine mix concrete and leveling up the spot and blending it in with a broom. Will this work? How long should I wait before I attempt this repair? Any better ideas? It won't kill me just to leave it that way but I would rather it be perfect if that is possible. It was poured yesterday.
Thank for your help
Dan
