i built an addition on to a house .using a company to cut a doorway through the foundation for the lower level access when i had discovered that they didnt cover the cut area as well as they should have,producing quite the mess.my problem is there is some woodwork that has slurry on it after repeated cleanings with water &soap there is still a film.would somthing like mineral spirits do a better job–without stripping the finish off?thanks for readin-
Michael Hindle explores the efficacy of deep energy retrofits and discusses essential considerations for effective climate mitigation.
at this point you might be better letting it dry and the wiping it off...you might be forcing the slurry deeper into the crevicesa...
hard tellin, not knowin
LOL!! boy your a big help!! :)
I would call the concrete saw company and see what suggestions they have, like coming back and cleaning it up themselves!
Sounds like a communication breakdown. I have done miles of saw cuts, and the cutting companies supply a cutter and a saw. Job site protection and slurry vacuuming is the responsibility of the general. That said, soap and water, or a slight muriatic solution will be the way to clean the mess up. Mineral spirits will not do any good, because they are a hydro-carbon solvent, meant to clean up (generally) other hydrocarbons and associated compounds.
use muriatic acid from any brickyard or canadian tire sells it, wipe the floor with a damp sponge then mix a ratio of 5parts water to 1 part acid and sponge the floor withthe diluted acid wash and do not let acid wash dry on floor m as soon as done , you must wipe cllean again with clean water and wear rubber gloves.
post note , my .02: Always add Acid to Water, not water to acid. A to W
concrete cutting is a messing job, no matter how hard you try to stay clean, its just not possible. I know of not any concrete cutting company that cleans up behind their selves
hiiron,,
Try some straight vinegar. Rinse well.
KK
