Concrete testing
FastEddie | Posted in General Discussion on April 27, 2007 12:18pm
Got a lab report back for some concrete cylinders used in a foundation of a 2 story building.  28 day design strength was 3000 psi, one cylinder broke at 3160 and the other at 2850.  It’s not often that I see numbers below design strength, so I’m curious how important this is.
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. brownbagg | Apr 27, 2007 01:10am | #1
    its not,they average out to 3005
  2. VaTom | Apr 27, 2007 02:43am | #2
    The woman I knew who worked for the testing co here said they never saw under 3500 for 3000 spec concrete.  Which is exactly what the readymix salesman told me, not that I believed him.  Apparently they actually did always add that extra sack.
    1. FastEddie | Apr 27, 2007 02:47am | #3
      This is on a project I just took over, and I'm not entirely thrilled with the gc.  On the other job I have going, different gc, the 3000 psi cylinders are testing over 3800, many over 4000."Put your creed in your deed."   Emerson
      1. brownbagg | Apr 27, 2007 03:33am | #4
        it was poured wet, but it still met specification
        1. FastEddie | Apr 27, 2007 03:28pm | #9
          I'm not sure it was poured wet.  Looking at the test report:
          admix - flyash
          mix design - 3000 psi
          air content - 1.5%
          concrete temp - 43*F
          water added - 0 gal
          slump - 5.0
          water withheld - 2 gal
          Brownie - what is 'water withheld'"Put your creed in your deed."   Emerson
          1. brownbagg | Apr 29, 2007 05:53am | #11
            water withheld is the allowable water they can put in, The temp was 43 on a flyash mix. This concrete is almost frozen so it will be a very slow mix, But and big but that nobody here will notice. The break met spefication. It was a 3000 mix, it broke 3000 psi, there is nothing wrong here. The concrete is fine, ok, nothing wrong with.a lot of mix will break high, that gravy, it a mix meet spefication that all that matter. since one cylinder went over spec. it metalso it a cylinder is under by 5% it still meet spec.
            Edited 4/28/2007 10:57 pm by brownbagg
        BillHartmann | Apr 27, 2007 07:40am | #5
        Did you see my response to the thread about checking to see if the CBU's had been filled?I looked back for it and can't find it.It should not have been delete or moved unless some one went off in the thread..
        1. FastEddie | Apr 27, 2007 03:23pm | #8
          I read that.  I was hoping for something easy, like a hammer tap."Put your creed in your deed."   Emerson
  3. davidmeiland | Apr 27, 2007 07:56am | #6
    It's been a while since I had to have concrete tested, but the 3000psi tests came back between 3500-4000. You're probably OK anyway, unless the BI speaks up.
    1. gb93433 | Apr 27, 2007 09:37am | #7
      I have a friend who design runways for the government and he once told me that they now use much lower strength concrete and make it thicker because when concrete fails the problem is almost always the subgrade.When you consider the fact that concrete essentially has 0 tensile strength then its strength is in compression only does that little difference really matter all that much when one considers where most of ti goes? Recently in a lab they were able to produce 30 ksi concrete
  4. brad805 | Apr 27, 2007 07:58pm | #10
    It really depends upon the concrete use.  Suspended slab...very important, footing...somewhat, but footing dimensions largely dependent upon soil strength which is far less than concrete, foundation wall...can be very important depending upon your backfill conditions, slab on grade...in cases where durability is critical, yes, but for your typical residential applications recent reports in the ACI suggest less important than once thought.
    You should also remember that concrete tests really only give the maximum potential strength and may not really represent the actual strength of the concrete on site because when they take the cylinders back to the lab they are put into a water bath where they sit until the day they need to be tested.  Concrete strength is dependent upon curing conditions, and the curing conditions in the lab are ideal whereas the site conditions rarely are.
