Continuously Insulated CMU
| Posted in General Discussion on June 25, 2000 10:00am
I am trying to find a product that I remember reading about, but don’t remeber the name of. It was an insulated CMU block. However, it was not simply traditional CMU w/ insulated cores, but a block in which the interior and exterior faces were completely isolated from each other by a continuous ribbon of poly-something-or-other. T-shaped fins on the inside of each face helped the faces interlock.
Does anyone know of such a product? Better yet, has anyone used anything like this? Comments?
  1. ybrp01 | Jun 02, 2000 08:26pm | #1
    I remember the product name now: Thermalock.
    Anyone used this before?
    1. Steve_Hansen | Jun 05, 2000 02:36am | #2
      *I was unable to find a site for "ThermaLock" but did locate the following address:ThermaLock ProductsConcrete Block/Water Proofing162 Sweeny StreetNorth Towawanda NY 14120800-537-6363Also some related information at http://www.buildinggreen.com/elists/cemmasonry.html . Check out the last post in particular.I note that CMUs are expensive to ship. About $2 per mile for a truck load. Unless you can find a licensed manufacturer in your area the cost of using these could be prohibitive. Consider ICFs.
      1. Dallas_Whitford | Jun 25, 2000 10:00pm | #3
        *ybrp01, Inifinty Blocks by IMSI should be of interest to you if available in your area. try---165 Mountain Way Drive Orem, Utah,84048 801-235-1565 ax 801-235-1567, [email protected]
  2. ybrp01 | Jun 25, 2000 10:00pm | #4
    I am trying to find a product that I remember reading about, but don't remeber the name of. It was an insulated CMU block. However, it was not simply traditional CMU w/ insulated cores, but a block in which the interior and exterior faces were completely isolated from each other by a continuous ribbon of poly-something-or-other. T-shaped fins on the inside of each face helped the faces interlock.
Fast, Accurate Wall Framing
