Controlling lights from the tub question
I’m still roughing in electrical and need a strategy that will comply with the NEC. I want to be able to switch/dim the light over my whirlpool tub while using the tub. It’s just one can light.
I know that I can’t place a typical switch or dimmer beside the tub, so what is the most practical solution?
Air switch? IR remote?
Thanks.
New knowledge is priceless.
Used knowledge is even more valuable.
Get a ceiling fan with remote fan speed and light control.
clapper
You must be single....
"the most practical solution.."
switch/dim the light before you get in the tub ???
Clapper.
Well, maybe not if it gets noisy in the hot tub.
Damn, Mark! I read the OP, immediately thought of a clapper, and scrolled to the bottom - only to find that you had already done that.Curses.........Foiled Again - lol
hey i was first with the clapper idea, credit where credit is due!
Oops, my bad. - lol
just don't let it happen again.
don't know where i got em... but... they are touch dimmers you wire em into a light or lamp and then a wire to anything metal (maybe a towel bar) guess they are whats in the lamps you touch the base of to turn off & on... guess it'd be safe? a wire to a thin sheet metal plate that'd be behind the drywall or tile... that would catch a screw from the towel bar?
p
