I have to repair or replace a roof on a 1″ rise to 12 ” run roof in northern Utah. The current roof is tar and gravel. An additional problem I would like to solve is one of thermal insulation. The upper floor of the house, built in 1953, takes on a huge heat load in the summer (and I am sure that heat goes escapes during the winter). I am considering a spray polyurethane foam roof with a white plastic or rubber cover OR a rigid, single ply roofing and insulation material which will also be covered with a white plastic or rubber cover. I can find considerable information about the use of this kind of “cool roof” system for commercial buildings but not for residential. Any advice would be appreciated. Fee
Fee,
On flat and sloped roofs I use 2" foil-faced (both sides foil is always stocked around here...CT) polyiscyanate insulation. About R-13 for the two inches. Gap the sheets 3/8" or so, then use canned foam to seal the gaps, then use 2" Al tape to make the foil continuous over the foamed gaps.
Does an absolutely fabulous job of limiting solar/radiant heat gain into the living space.
