Cork flooring in a washroom?
silver | Posted in General Discussion on November 17, 2006 07:15am
My customer wants to put cork flooring in her washroom. This a high end click laminate with an mdf core and cork on both sides. Her partner is a quadriplegic and some water will be splashed on the floor when she takes him out of the tub with the lift.
Is cork appropriate for this situation??…she really doesn’t want ceramic because it’s too hard and she thinks vinyl will be too slippery.
Sure would appreciate your opinions,
thanks!
silver
    johnnyd | Nov 17, 2006 07:55pm | #1
    Is it the kind that clicks together and floats?
    If so, you'll have some seams to consider.  We have that type on a bedroom, hallway, and living room floor, so can't really speak to how will it repells alot of water.
    Maybe ask the manufacturer?
    FWIW, many of the older exam rooms in the world famous Mayo Clinic are cork.
    BillHartmann | Nov 17, 2006 08:05pm | #2
    What does the manufacture say?
    I really don't know, but for an application like this I would be looking other forms of cork.
    Maybe a gluedown with a sealer coat after installed.
    1. silver | Nov 17, 2006 08:54pm | #3
      The manufacturer's warranty is basically giving themselves an out no matter what happens: "inadequate product choice for the flooring use conditions, damage due to exposure to excessive heat, wetness or dryness, problems caused by moisture, mildew, alkaline substance......"!Do you have a source for the glue down cork?This woman is absolutely paranoid of someone slipping on tile or vinyl...since her partner had a severe head injury.
      Suggestion for a flooring...she doesn't want wood either and has allergies to carpet....we thought maybe combining tile and the cork, putting the tile around the tub and toilet area....but that could look like hell.Thanks for your help
      Silver
        BillHartmann | Nov 17, 2006 09:06pm | #4
        I don't have a sorce for the glue down cork. But a google on cork flooring with find some. And where you get a distributor then get the brand name and google on that.As to the slipperness of the vinyl I know that tile has a rate of coefficent of friction, COF. And there is a number which they recommend as a minimum (or it a maximum) for tile floors where they will get wet.See if have the same for vinyl.
        1. silver | Nov 17, 2006 10:18pm | #5
          Thanks Bill...tile may be a possibility.silver
            BillHartmann | Nov 17, 2006 10:30pm | #6
            BTW, when I said tile it was for ceramic.Don't know if they rate either vinyl tile or sheet for COF.Might want to check the commercial VCT. They are more likely to be rated.
      2. deskguy | Nov 18, 2006 03:36am | #8
        How about a nice rubber floor.
        http://www.cartwheelfactory.com/rubber_flooring.html?gclid=CNzDmN2pz4gCFSbUYAodSRm9Ow
        skid resistent and shock abcorbent, heck, put some on the walls in case their head hits that on the way down.
        good luck, post back on what you do/use.  I was tempted to use cork in our next bathroom if it's feasible, but haven't done any checking yet.
  3. MGMaxwell | Nov 18, 2006 12:48am | #7
    Go to duro-design.com. They have excellent customer service and you can find the tech specs online. I recommend the glue down. However, it is slippery when wet.
    cuidado resbala quando majado. My next tattoo.
  4. IdahoDon | Nov 18, 2006 03:48am | #9
    Especially if you know it will be splashed with water, this might not be a good option for such a wet location.
    I have yet to see a finished piece of any kind of wood hold up in wet locations, let alone engineered wood.
    1. silver | Nov 18, 2006 08:49am | #10
      Thanks to everyone for their thoughts and advice...Fri. night and I've had a Molson XXX and working on a gin and tonic so I can kick back for a minute.mdf core!!WTF was I thinking-wake up cowboy and smell the coffee...not even common sense would say, "sure put mdf in a wet area". Reckon I was going a bit too fast this week-Well like my drywaller says -time is money and my personal favorite...the faster you go, the more money you make...Anyway, seems I have been going a bit too fast and I believed the salesman when he showed me a very beautful product and assured me it was the right product for that situation. Also known as, "I have what you need"... all he was thinking about was his commission.I gotta thank my plumber when we set the tub at 9:00 am tomorrow for his advice-"Phil, I've seen a couple of these fancy floors get torn out because the wax sealon the toilet leaked .I'm buying that man a bottle of Kahlua for his black Russians and now doing my research on the right floor for that area.Carol has agreed to vinyl but I have a small prejudice against it and
      need to research the slipperness issue. Thanks for that info ,Bill.cheers, hi ho silver
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
