Having my place sheetrocked next week. I have seen cb taped, my installer says it makes it harder to repair a crack. Is it worth it to tape it, or just mud it?
If you're talking metal corner bead, the tape will make the corners less likely to crack. Even if it did crack, how would the tape make it difficult to repair?
I now prefer No Coat corners, Install the corner bead and tape in one step
I keep on hearing about these no coat corners. I have used them on non 90 degree applications, but can you really get them square and plumb on typical corners. Or rather should I trust a drywall installer who may not be used to using it in that application.
With the roller I think they are easier to install straight & square than the metal corners. Especially for the hangers. <g> We always had the finishers install the bead themselves, so they couldn't complain about the hangers screwing them up.
Barry E-Remodeler
