Still working out some details in the construction of a 7′ x 7′ bathroom in a basement remodel.
I’ve got a couple of preexisting conditions (furnace location and vent stack) that limit how and where I can move things.
I’m thinking now of maybe doing a corner shower, rather than a 3′ x 4′ shower.
The shower will be tiled, walls and floor.
2 questions:
-If I build the pan myself are there drawbacks to making the shower custom sized, as long as I frame it out for the appropriate shower door?
-Has anyone used any prefab shower stall pans that are meant to be tiled over?
I’m trying to figure out the pros and cons without having installed one myself before.
Paul
A preformed plastic shower pan isn't intended to be tiled. (The flex and slipperiness of the surface prohibit tile adhesion). There is a system by Kerdi that uses preformed styrofoam that is covered with waterproofing material and tiled. Check out the Schluter website to see examples. If you're going to do a custom pan just be sure not tear the corrolay and if you haven't floated a pan before, use the "goof proof shower pan" that helps a novice perfect the slope to the drain.
Hope this helps.
