In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
cornice return retrofit
| Posted in General Discussion on May 10, 2000 03:41am
help-I have a turn of the century victorian that had “in soffit” gutter system that I demo’d after it had done its damage. I would like to install conventional gutters, but the rake on the fascia is not plumb and it would look very awkward having the ends of the gutters displaying themselves at each gable tail. Can one retrofit a return that incorporates the gutter and maintains some sort of esthetic elegance.
  1. Guest_ | May 10, 2000 04:04am | #1
    use roof hangers and a half-round gutter
    1. Guest_ | May 10, 2000 03:40pm | #2
      *MIke's right that half-round is probably the best aesthetic solution. You may want to upsize them though since their cross-sectional capacity is much lower than k-gutters.Installing hangers to hold the circles will involve the roof edge a bit. Ideally the top of the hanger gets mortised flush with the sheathing (anyone doing it 'right'?) so it doesn't make a lump in the roofing. If you use copper gutters the roofers around here advise against copper hangers - too soft and bend too easily. Plated / galvanized doesn't seem to cause galvanic action problems with the copper, although technically it should.I think you might make the 'end view' worse by attempting a gutter return, even with some sort of enclosure.Good luck
  2. John_Maurer | May 10, 2000 03:41pm | #3
    help-I have a turn of the century victorian that had "in soffit" gutter system that I demo'd after it had done its damage. I would like to install conventional gutters, but the rake on the fascia is not plumb and it would look very awkward having the ends of the gutters displaying themselves at each gable tail. Can one retrofit a return that incorporates the gutter and maintains some sort of esthetic elegance.
How to Install Exterior Laminate PVC Siding
In this video, learn how hidden fasteners make for a seamless feature wall.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
