Does anyone know where I can get wide pine or hickory flooring that would be suitable for installation over a slab floor. I need to install about 1000 s.f. in several medium sized rooms. The house is a 10 year old Southern California home that is in excellent condition, with no moisture problems.
There's a constant source of clean water for you to use, and all you have to do is collect it.
Hey John!
How wide is wide? Most flooring will have to be applied over a vapor controlling membrane, with 3/4" ply cemented over that, utilizing a adapter shoe for your nailer (if you're angle nailing).
Some sources can be found on: http://www.abuildnet.com
by using their search function.
