Cracking windows
| Posted in General Discussion on June 23, 2002 02:26am
I am working on an enclosed porch that is built on a floating slab.(No footing under slab). The windows are storm windows that are caulked and screwed tightly to the frame. They have been cracking I think because of the frost heave. I want to replace all the windows with vinyl replacement windows. I was considering ordering them an inch smaller than the rough opening and using some soft foam cushon padding to fill to fill in the gap. Will this work ? Is there a better way?
John Keller
  1. Piffin | Jun 23, 2002 10:55pm | #1
    I usually try to fix the problem. You've identified it. Now if you don't fix it, there will be several other symptoms show up besides the window situation.
