Crawlspace Encapsulation
user-127875 | Posted in Construction Techniques on March 22, 2006 11:41am
With a brick veneer wall 2inches out from the outside blocks/wood wall how would you complete crawlsapce encapsulation?
  1. philarenewal | Mar 23, 2006 01:39am | #1
    Hey Charles, if you explain what it is you are trying to accomplish, you'll likely get more answers.
    Also, are you saying the siding on the house does not stick out as far as the brick veneer below it?  Or are you saying there is 2" of airspace between the brick veneer and the blocks behind?  I can't tell what you are getting at because I'm not sure what you're trying to do.
    If you truely wish to "encapsulate" the crawl, try the link below.  It includes photos of "encapsulation" (before launch).  ;-)
    http://mars.jpl.nasa.gov/msp98/images/ksc981110.html
    "A job well done is its own reward.  Now would you prefer to make the final payment by cash, check or Master Card?"
    1. user-127875 | Mar 23, 2006 03:49pm | #2
      We are installing a Crawlspace Encapsulation System in the crawlspace.  There is air space between the brick veneer and the blocks.  If you would like to know what Crawlspace Encapsulation is go to http://www.crawlspace-basementsolutions.com and this will explain to you what it is and why it should be done.
      1. JohnT8 | Mar 23, 2006 04:54pm | #3
        Charles, I'm doing something similar with my project house.  Assuming they are sealing the top of the vapor barrier, something to keep in mind is that you don't want the vapor barrier to run right up to the sill.  You would be giving termites a hidden path into your house.
        And if you are going to completely seal the crawl, you are going to start up the argument between the "sealed crawlspace vs. vented crawlspace" people.
        "When you take charge of your life, there is no longer need to ask permission of other people or society at large. When you ask permission, you give someone veto power over your life." -- Geoffrey F. Abert
        RichBeckman | Mar 24, 2006 04:35am | #4
        Charlie,I am at a complete loss as to how this air space might effect the sealed crawl.Maybe a pic or a drawing?Rich BeckmanAnother day, another tool.
