Crawlspace insulation – in or outside
I’m in northern MN and have a 1 story ranch on a block crawlspace. I’d like to insulate the crawlspace and wonder if it’s better to dig, put foam on the outside and cover it with stucco-like product or glue foam on the inside? The crawl has a dirt floor with a half-a**ed plastic barrier on it. Moisture doesn’t seem to be a problem. Heat is forced air with the ducts in the crawl.
Thanks, Ted
Greetings sweetlake,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
'Nemo me impune lacesset'
