Crazy caulk question
glatt | Posted in General Discussion on February 14, 2006 01:36am
You probably haven’t heard this one before. Who knows? Maybe you have.
My boots are falling apart. The uppers are in great shape, and the treads are hardly worn at all, but the foam that is sandwiched between the treads and the leather uppers is beginning to deteriorate along the edges. The foam looks a lot like neoprene.
I tried using “Shoe Goo” to seal the edge of the foam to keep it from deteriorating more, but the “Shoe Goo” is not flexible. It is so rigid, when the foam in the sole compresses as I take a step, the “Goo” doesn’t flex. The two dis-similar parts then separate. The “Shoe Goo” is now peeling off and looks horrible.
So I thought a caulk might do the trick. I need something that will flex a little bit when I take a step, will stick to rubber, and will be water proof. The caulk will need to bridge the gap between the hard rubber treads and the hard rubber that is attached to the leather upper. It will cover over the foam (neoprene?)that is the middle of this sandwich.
Any ideas?
I know this isn’t a construction question, but I thought somebody here might know the answer, and save a pair of otherwise nice boots.
Thanks!
  1. FastEddie | Feb 14, 2006 02:17am | #1
    Elastomeric caulk.  Sonneborne is one.  Also PL urethane caulk.  It's like working with a combination of peanut butter and honey.  You will probably have to not wear the shoes for about 48 hrs to let the stuff fully cure, otherwise it is a little sticky.
  2. JohnSprung | Feb 14, 2006 02:50am | #2
    I've used construction adhesive on those last-legs ready to be tossed after one more concrete job type shoes.  A couple wraps of duct tape will hold them together on your feet, too.  Come to think of it, I have a lot of those about ready to be tossed shoes.
    -- J.S.
    JeffBuck | Feb 14, 2006 03:21am | #3
    another vote for PL Premium.
    glued the last "old pair" and they're still good for mud work.
    That ... or any good "siliconized" caulk should work.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
  4. blue_eyed_devil | Feb 14, 2006 04:48am | #4
    Wide crown staples. Bend over the legs.
    Take your feet out first.
    blue
    1. glatt | Feb 14, 2006 04:39pm | #5
      Thanks, guys!
      1. saulgood | Feb 14, 2006 07:40pm | #6
        Sometimes you can get your boots resoled, but I think you need to have your laces rebooted.
