Crazy motion sensor and a three-way.
I have an electrical question. I recently intsalled a motion detector on an outside electrical box. The switch for that fixture is in a tree-gang box along with two other switches, both of which are three-way. If the motion sensor is energized, and I turn on the flourescent fixture in the kitchen, the motion sensor light will come on. Is something wired incorrectly, or is this a characteristic of three-way switches? I am a cabinetmaker and don’t know very much about electrical work, so I would appreciate hearing from someone who does. Thanks.
If the motion sensor light stays on permanently, then things are wired wrong. If it just comes on and goes off after a time-out period as if it had been triggered by something moving, then the problem is a transient from switching one light fooling the sensor for the other.
-- J.S.
Thank-you for your reply. By transient do you mean the traveller wire in the three-way wiring, or something else. Thanks again.
A transient is an event, not a physical object. It's electronic noise, a glitch in the voltage waveform caused by switching a load on or off, or by a noisy load. For instance, a pop noise on a radio when you flip a switch is a transient. Speckles on your TV picture when you run an electric motor are transients. It may be that the electronics in the motion sensor get fooled by a strong transient from switching another load nearby on the same circuit. In designing the motion detector, they had to make a tradeoff between cost and immunity to transients.
-- J.S.
Thank-you for a most informative reply. I now see what you mean by a transient.
