A friend is putting up crown moulding in his house. He wants to end it at an outside corner.
Is there a standard (or more than one) way of doing that?
Thanks,
Alan – planesaw
Thanks,
Alan – planesaw
Return to wall, end cap, block.
Some with return the moulding to the wall just short of the outside corner. Others will wrap the crown just past the outside corner, returning to the other wall. Whatever looks the coolest for you buddy.
Quittin' Time
I like making a mitered return to finish the end. The crown returns on itself and dies into the wall.
I keep the end about 1/8" to 1/4" from the outside corner.
"Is there a standard (or more than one) way of doing that?"
Planesaw,
This is how I did mine.
WSJ
Edited 8/26/2006 3:41 pm ET by WorkshopJon
And photos make the words even clearer.
Thanks,
Alan - planesaw
I like 22.5º returns, rather than the 45º returns that die right into the wall.
To make a 22.5º return, cut two 22.5 angles, one on the long piece and one on the return, and then a 45 on the other side of the return.
Here's a site showing 22.5º returns on base. They work the same on crown. http://www.garymkatz.com/TrimTechniques/22wallreturns.htm
zak
"so it goes"
That is different.......I like the subtle change.
Semper Fi
Check out thread #77623.1 on open ends on crown molding... some other great ideas.
(sorry I'm not sure how to link to another thread)
Once you find the thread you want to link to, click on the first message so you get the URL in the address bar, then just copy and paste:
http://forums.taunton.com/tp-breaktime/messages?msg=77623.1
got it .......thanks.
