I’m pouring footings for a deck here in WI: 4′ deep, 8″ diameter, using premixed bag concrete. How long before I can start putting up my posts?
Thanks,
Tom
Thanks,
Tom
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
Many variables, moisture, temperature, mix, eetc.Maybe one day three generally plenty safe. Occasionally a week with wet mix, cold temp.
I usually start posting the following day setting temporary supports around deck perimeter to keep wieght off peers until they cure. I leave temps in place until deck is complete or they start to get in the way.
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
TomD--
Piffin covered the basics. In addition, helps to keep tops moist/damp as long as possible. Old burlap bags, cardboard or even newspaper work well. The "curing" is a continuing chemical process which requires water. Evaporation can cause the tops to dry out early.
Regards,
Rework
Thanks everyone, just what I needed to know.
Tom
