Curved transition
kmrsy | Posted in General Discussion on October 18, 2009 12:25pm
Hi!, I’m a gardener, not a homebuilder, but I’m hoping y’all will be willing to help me out…
I just had my living room floor redone. Nice beige/tan ceramic tile at the entry and the room is Bruce spice solid oak planks, 3/4 inch thick. I wanted the ceramic tile to be cut in a curve instead of straight lines. It came out beautifully, until I saw the thick black rubber transition piece the contractor put in.
It’s ugly, 1+1/2 inch wide, very industrial looking. I told him it had to be changed. Surely someone makes something flexible of that width in a tan, beige, light brown, taupe, something besides black or white!
Can anyone here suggest something and where I might find it?
Thanks!
_^..^_ Kitty, neIN, Z5
  1. DanH | Oct 18, 2009 01:24am | #1
    I assume you're talking about a slightly domed rubber-like strip that fits over the joint between tile and whatever?
    The time to discuss the appearance of this is, of course, before the work is done -- very often it's possible to avoid the strip entirely with a little more effort, but it's probably a bit late for that.
    I have seen the strips in other "neutral" colors, but I don't know what the color options are.
    But here's one web site (many more):
    http://www.installerstore.com/catalog/Johnsonite-Vinyl-Transition-Strips-p-1-c-248.html
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    1. kmrsy | Oct 18, 2009 01:50am | #3
      Thanks, Dan. I think the problem is the width he requires. 3/4 inch each way. That site didn't show anything that wide. Not sure why it needs to be. Yes, it should have been discussed beforehand but when I said, "I want a subtle flow of color from the ceramic to the wood", I thought he understood.Thanks for your help._^..^_ Kitty, neIN, Z5
      1. DanH | Oct 18, 2009 01:59am | #5
        He needs 3/4" each way because the joint is that poorly fitted.
        1. kmrsy | Oct 18, 2009 02:30am | #6
          If that's the reason, then I thinks it's not that it is poorly fitted, but rather overkill. I looked it over before he installed the transition, and it was spot-on. It looked to be no more than a 1/4 inch, perhaps less, gap between the materials throughout the curve. Or did you mean a difference in heights? Not that either. The subflooring he added to raise the tile to the height of the wood also felt right on. He tends to be quite the perfectionist and does great work. No complaints except the color._^..^_ Kitty, neIN, Z5
          Edited 10/17/2009 7:31 pm by kmrsy
  2. calvin | Oct 18, 2009 01:31am | #2
    I did a search for "flexible tile transitions trim"  SEARCH
    and found this among others:  Installers Tile Store
    Colored Caulk
    Caulk Strips
    Custom Building Product Colored Caulk
    Dap Caulk
    Hydroment Colored Caulk
    Tec Colored Caulk
    Colored Grout
    Cove Base & Transitions
    Cove Base Adhesives
    Johnsonite Transitions & Flooring Adaptors
    Flexible Transitions
    Johnsonite Cove Base
    Doormats & Chairmats
    Chair Mats
    Coir & Decorative Welcome Mats
    Commercial Entrance Mats
    Welcome Door Mats
    Embossed Tile Transfers
    Transfers
    Floor Cleaners & Floor Care
    Bona kemi Cleaner
    Carpet Spot Remover & Carpet Cleaners
    Ceramic Clean & Seal
    Forbo Maintenance Products
    Grout Sealer & Cleaning
    Hardwood Floor Cleaning & Care
    Laminate Floor Cleaner
    Mops & Mop Care Kits
    Stone, Granite & Marble Polishing & Cleaning
    VCT Polish & Cleaner
    Vinyl Cleaning
    Floor Protector
    Carpet Masking and Protector
    Furniture and Chair Protectors
    Hard Floor Protection
    Misc. Floor Protection
    Slipstick Furniture Protector
    Floor Registers
    Air Deflectors
    Baseboard Registers
    Brass Floor Registers & More
    Custom Metal Grille
    Floor Registers
    Flush Mount
    High-Density Plastic Resin
    Marquis Floor Registers
    Sidewall Registers
    Sidewall Return Grills
    Standard Floor Registers
    Wood Floor Registers
    Floor Repair
    Carpet Repair Kits
    Caulking Tools
    Grout & Tile Repair
    Hardwood & Laminate Repair
    No Slip Floor Products
    Squeaky Floor Repair
    Vinyl Flooring Repair
    Instabind Carpet Binding
    Regular Carpet Binding
    Rope Carpet Binding
    Serge Carpet Binding
    Miscellaneous
    Anti Slip Tape
    Adhesive Remover
    Carpet Base
    Hazardous Testing
    Stair Rods
    IS Carpet Clips
    IS Carpet Rods
    IS Tapestry Hangers
    Specials
    Zoroufy Stair Rods
    Zoroufy Stair-Holds
    Zoroufy Wall Hangers
    Affiliate Program
    View ImageView ImageView ImageView ImageView ImageView Image
    Straight Snap-in T-Molding
    522-TS
    Flexible Trim for Floor Transitions
    Flexible trim for your new floor transition needs. Use this tile or carpet transition with the standard metal trackbase. Works great as a carpet transition that contours around curved vinyl floors. SnapDown is a revolutionary snap-in t-molding due to the fact you can adjust the height on site by peeling off sections of the "T". Can be used with most flooring: tile, laminate, wood, vinyl or carpet.
      Additional Information
    • Flexible PVC Vinyl
    • Height adjusts from 1/2" to 1/4"
    • Works with standard metal track base with pins or without
    5 Colors to choose from (all monitors show colors differently please email for
    specific color sample):
    Flexible Transition Color Choices
    This product is sold by the foot and will be cut to what you order (up to 50 feet max length).
    << Back to Cove Base & Transitions;Flexible Transitions list...
    Sorry the page is so damn big.  There's your copy/paste.
    http://www.quittintime.com/
    1. kmrsy | Oct 18, 2009 01:57am | #4
      Some of the items on that site seem as if they might be what I need. I can only make out a rough idea from the info provided, but it looks like it's heading in the right direction. Thanks!_^..^_ Kitty, neIN, Z5
  3. JohnCujie | Oct 18, 2009 02:46am | #7
    If there is an even space between the two materials and they are at they same elevation, why can't it be caulked with a caulk to match the tile grout? They make matching, sanded caulk. It will look just like a grout joint.
    Unless the cut edges of the tile are rough where they were cut at the curve.
    John
    1. kmrsy | Oct 18, 2009 06:00am | #8
      Thanks. I'll check that out with him. You guys are great!!
Flashing a Window Using ZIP Tape
Travis and Joe walk through the step-by-step process of prepping, caulking, and flashing a window using stretch tape and flashing tape from ZIP System.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
