Custom sliding doors
| Posted in General Discussion on May 12, 2001 02:10am
For an upcoming job I need to find or make some sliding glass doors, using barn door or similar hardware. Three panels, two operable and one fixed, mahogany frames and insulated glass panels. I got a quote for $10,000 from a custom door company, I’ve built doors and windows before so I’m comfortable giving it a try ’cause I think I can do it for less than 10k. I’ll use vertical grain stock, mortise-and-tenon joints, exterior glue.
What’s the best way to set the glass into the frames? Any advice on hardware companies? Solid or laminated wood members?
Thanks for any advice,
Mike
  1. Mike_Maines_ | May 12, 2001 02:10am | #1
    For an upcoming job I need to find or make some sliding glass doors, using barn door or similar hardware. Three panels, two operable and one fixed, mahogany frames and insulated glass panels. I got a quote for $10,000 from a custom door company, I've built doors and windows before so I'm comfortable giving it a try 'cause I think I can do it for less than 10k. I'll use vertical grain stock, mortise-and-tenon joints, exterior glue.
    What's the best way to set the glass into the frames? Any advice on hardware companies? Solid or laminated wood members?
    Mike
