Score and snap straight is easy. Score and punch for small holes like the faucet leads is easy.
But what is the best tool and method when cutting it to a large curved pattern, like the cutout for a deckmount oval tub?
In issue #314, Fine Homebuilding published an article titled “The End of Deep Energy Retrofits” by Rachel White of Byggmeister. The premise was that deep energy retrofits are not as…
I use a rotozip with a 1/4" crosshatch tile cutting bit
In the tile dept of Lowes and HD they sell a bit for a jigsaw, it has carbide grit rather than teeth. The Hardie will still eat it up, but it should last for one bathroom project.
another that works, if you already happen to have a beat up skil saw and a hardie blade, is to set the depth real shallow - just 1/4" so not much of the blade is engaging the work, Then you can make shallow turns like that pretty easy without binding things up.
Ditto Fasteddie - the jigsaw blades available around here are called Rem-Grit and sold as individuals on cards. Also work well on ceramic wall tile - useless on floor tile.
I do enough tile work that I keep the blades which are too worn for tile - still work great for 1/4" Hardi.
Jim
