FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Cutting a tub drain insp. hole?
sleddriver | Posted in General Discussion on November 2, 2006 03:28am
I need to cut out an inspection hole in a kitchen dining area as neatly as possible. The drywall has wallpaper on it. This wall is common to a bathroom on the other side and I need access to the tub drain.
Instead of water backing up into the tub (which is last in line plumbing wise,before the main black water line leaves the foundation to the septic tank), it leaks out at the tub-drain joint and flows out onto the floor. I’m looking forward to fixing this one!
I’m seeking advice on how to cut out a large enough section of wallpaper covered drywall to minimize damage and when put back together, will look nice, since it will be in a very visible location.
Thanks in advance for your reply!
  1. plumbbill | Nov 02, 2006 03:39am | #1
    Is the wallpaper in good enough shape to steam it off from seam to seam?
    Edit to add---- is this slab on grade?
    “It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
    Edited 11/1/2006 8:40 pm ET by plumbbill
    1. sleddriver | Nov 02, 2006 04:42am | #2
      The wallpaper is in excellent shape and stripable.The wall is a simple 2x4 bottom plate/studs on concrete foundation. I just realized . . . the tub sits parallel to and right up against an outside wall. Sheathing is 1/4" or so standard plywood. Perhaps I could pull a section of it off and go at it that way? Don't know if I'll have access to the drain from the side of the tub though.I'm wanting to get this done ahead of time so that when my plumber friend comes over, it'll already be done.
      1. plumbbill | Nov 02, 2006 05:02am | #3
        OK
        Slab on grade means there is a "buck-out" for the tub drain.
        If water is coming out from the wall when another plumbing fixture is being used , it could very well be a leak in the pipe somewhere else.
        Path of least resistance & it's coming up through that buck out.
        If it's only leaking when the tub is draining, might have the problem in the waste & overflow connection to the trap or the trap itself.
        Could be able to get to it from the outside, but that could be a tough reach.
        Peeling the wall paper from seam to seam, & do a cut & patch a few inches away from the seam is actually pretty easy---- biggest part is peeling the wallpaper & putting it back without it shrinking.“It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
        1. sleddriver | Nov 02, 2006 05:39am | #4
          I now remember my plumber friend mentioning the "buck-out". I'm assuming this is what I have, but it's only a guess.I think what is going on is that there is a rough pvc edge or uneven pipe cut or poor joint, etc. in the soil line which catches some toilet paper and waste every time it goes by. Over flushes, it builds up. When it obstructs enough of the pipe, the shower or a toilet flush or washing machine discharge will flow enough water through there where it can't exit properly, and because of a loose or rusted connection at the tub drain/trap, it flows out there instead of backing up in the tub. I have run a long snake through the closet vent stack and also through the clean out just upstream of the septic tank. I don't use the kitchen disposer much, so I'm assuming toilet paper and waste build-up.I'd suspect stripping the wallpaper would stretch it and it wouldn't go back on right. Not much experience with wallpaper.Thanks for your reply
          1. fingersandtoes | Nov 02, 2006 06:14am | #5
            This may sound like an odd thing to do, but I have started putting a circular 4 inch wall vent in my new houses so that I can look at the tub drains without cutting a hole later. I was taken to small claims court for damages to a bathroom floor and walls that were caused by teenagers showering without the curtain shut. The owner blamed it on faulty plumbing and the only was to prove my case was to cut an inspection hole. I won the case but the judge gave her $200 for drywall repairs!
            No new owners have ever questioned the presence of the vent. I doubt many of them have even noticed it.
Double Dormer Transformation
This historic schoolhouse was transformed into a stunning four-bed, three-bath home with ocean views and a modern open-concept design.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
