hello,i am cutting baseboard trim in the bathroom.i was noticing that the miter box with hand saw cuts the angle at a not a true 45 degrees.on my compound miter saw i put the bevel on 45 degrees and set the miter at 4 degrees to achieve this angle with the trim face down.am i barking up the right tree.please correct.thanks jvl
Cut the baseboard profile face up at 45 deg and no miter angle.
I usually cut inside corners at 44 deg and outside corners slightly over 45 deg.
Gord
I trim houses for a living and while initially coping joints can have a learning curve, it is by far easier to get joints to fit tight. I cut the base face up with a 45 deg. bevel then cope out the remaining stock to allow for a tight fit. after a few pieces you will have it down I'm sure. remeber to use nails that are not too long for the base so to minimize the risk of hitting plumbing or wires.
"it aint the work I mind,
It's the feeling of falling further behind."
Bozini Latini
http://www.ingrainedwoodworking.com
Cope your inside corners for sure.
thanks everyone jvl
cope cope cope.
Learn to cope those joints and you will have a better job easier done.
