Search function just farded out on me when trying to find links to cutting tile sub-board Hardibacker.
Can that stuff be cut with a utility knife and snapped on a dowel?
The best tool for straight, splinter-free cuts is made even better without a cord.
Yeppers, score a few times tho'.
New book alert; Eckhart Tolle "A new earth"
A must read.
there's an 8$ carbide tipped scoring tool for this purpose that works reeeely reeeely well...
You'll find other uses for it too.
Oh yeah.. don't need a dowel. Just score and pull up. For narrower pieces, score both sides.
Edited 5/24/2008 5:50 pm by Waters
Rez,
The weird thing about Hardibacker is that you pull towards the scribe cut, which is the opposite of what you do with drywall, Durock, etc.
The 1/2" is very hard to snap off small pieces...tends to break in the wrong place. Even scored both sides it can be a pain.
The utility knife gives me a cleaner cut line than the carbide scriber, but the scriber lasts much better.
Bill
Depending on how much you do, shears might be the answer??
http://www.tools-plus.com/kett-kd292.html
Just slicing up 6" to 8" widths for a wall backing over a sink counter for tile.
Looks like a utility blade, both sides. Thanks all.
I take it outside and cut it with my circular saw.
Same here but even outside I still wear a mask. That stuff is nasty.
I'm not smart enough to wear a mask, but I will take it outside in zero weather before I cut it with a knife.
Get Smart.
When cutting hardi I make sure whoever is doing it wears a mask.
That stuff us nasty.
Bosch makes a sabersaw blade for cement board that works well. The dust is minimal,and can be cut inside.Most of the dust seems to pile on top of the board and is easily removed.
mike
