cutting plates for radius walls
| Posted in General Discussion on October 2, 2000 02:17am
I’m building an unusual custom home with many radius walls (3’5″, 4’5″, 8’0″, 13’5″, 17′, 56′, 92′, 288′).
Does anybody have suggestions on how to cut the plates for these walls? For the tighter radius, I’ve used a circular with every other tooth bent out in the opposite direction, increasing the kerf enough to make the curve. I’ve also used a sawzall and jig saw, with moderate results. I’d like to get a nice, clean (almost machine-like) cut.
I’ve also kerfed a 2×4 every few inches to enable the bend- this works OK in some situations, but I’d prefer to make the plate out of 1-1/8″ plywood, cut on radius with a good cutting technique. Any suggestions?
  1. Guest_ | Sep 24, 2000 05:45am | #1
    usually done with a good blade in a jigsaw... and double plate of two pieces of 3/4 ply.....
    your way sounds fine....
    1. Guest_ | Sep 25, 2000 08:55pm | #2
      *I use a product called FLEX-C- Trac Its a metal track that pivots evry 3 inches. It can recieve either metal studs or wood. I have onlt used on floors but the brochure shows barrel vaults columns and such. http://www.flexc.com It may not be as craftsman like as cutting a piece of wood with a router but its easier, no waste and if you cut the wood plate wrong you got to start over, with this stuff you just unscrew, reset and rerscrew. Good Luck.
      1. Guest_ | Sep 26, 2000 06:09pm | #3
        *Another alternative?For 1 1/8th ply, a router w straight bit on a trammel. Couple passes per cut. Easily repeatable, easily adjusted for varying radii, consistent results.
  2. The_Machine | Sep 28, 2000 08:34am | #4
    Mr. Casey,
    A circular, or worm-drive saw with a thin kerf 20-24 tth carbide blade should cut with precision the radii you've mentioned. Allow for about a little "fish-tail" in the blade. Take your time, practice.
    The Machine
  3. Guest_ | Sep 29, 2000 05:02am | #5
    I also would use the router with a trammel, but with double 3/4" plywood. I have never done this with such a large radius - I might suggest using 1/4" steel cable for the beam. It will be critical to keep the router held tight against the cable-beam so that the radius is held constant.
    92 foot radius??? Just what kind of house are you building?
    1. Guest_ | Oct 02, 2000 02:17am | #7
      *All of my straight cuts have a 90' radius!blue
  4. carl_casey | Oct 02, 2000 02:17am | #6
    I'm building an unusual custom home with many radius walls (3'5", 4'5", 8'0", 13'5", 17', 56', 92', 288').
    Does anybody have suggestions on how to cut the plates for these walls? For the tighter radius, I've used a circular with every other tooth bent out in the opposite direction, increasing the kerf enough to make the curve. I've also used a sawzall and jig saw, with moderate results. I'd like to get a nice, clean (almost machine-like) cut.
    I've also kerfed a 2x4 every few inches to enable the bend- this works OK in some situations, but I'd prefer to make the plate out of 1-1/8" plywood, cut on radius with a good cutting technique. Any suggestions?
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
