I was reading through Arch Graphic Stds and came across a table that says 2x yellow pine deck boards can span up to 5′. Seems like a bit far. What do you usually span?
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
It all depends on the load range required. A deck under the drip line of a steel roof in heavyu snow country might need to be designed for an 80# load. Most decks need about 50 - 60#. Some in the deep south are comfortable with 25 IF it is no more than three feet above ground. Note that we read every year about a campus party on the deck that gives way and kills somebody. Human flesh is heavy.
I think you might be reading your table wrong. I can remember lots of roof decks in the south sheathed with 2x6 T&G @5' or 6' OC where the required load rating was only about 15# Can't imagine framing a walkon deck that way though.
