In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Deck construction – advice wanted
DgH | Posted in Construction Techniques on September 1, 2004 06:09am
Deck Construction – advice
I am a beginner at home improvements. I have built (mostly) a deck this summer. The deck is built on a ledger on the side of the house (2, 2x8s) and the joists come out from the ledger to 16ft from the house (joists, 2×8). The beams at approximately 7ft and 14ft are doubled 2x8s. The structural elements are all pressure treated wood except for the rim joists and header which are cedar. The building inspector is perfectly happy with my choice of materials, spans, joist spacing etc…
When I hung my joists I put up all of my joist hangers at once. The wood goes on the hangers fine. The only thing is that in some cases because of the crown of the wood joists are slightly above beams by as much as 1/4″ in a couple of cases.
There was probably a better way of building this. However, now that it is constructed and the decking is on (5/4″x6x10 cedar decking)… I have not done the railings yet.
My intention to solve my space problem over the joists was to go under the deck after some load was built onto it (so the crowns of the joists would collapse a bit) and put in shims, then fasten them in place. At that point I would actually attach the framing clips I have partially in place (attached only to the joists, not the beams) to the beams as well.
Help. I could use an experienced opinion on this.
Thank-you.
  1. Piffin | Sep 01, 2004 07:04am | #1
    That all sounds fair to me, though I have some bar clamps that I would have used to pull the joists down to the beam before the deck was on. a quarter inch is within tolerance levels of framing and you can even find that a lot of framing lumber will vary by that much within a load. The more important thing is that the tops of jists are stright than to have them seated tight onto the beams. Shims are good.
    how you attache the posts for the railing could be an issue. I usually sink them in the framing behind the rim joists - or what you call the header. I have seen them lapped and bolted onto the face of the rim but that doesn't look as good or as strong to me.
    1. DgH | Sep 01, 2004 07:33am | #2
      Thank-you for the reply. It makes me feel much more comfortable to know that I am within framing tolerance. The top of the joists are nice and straight and level and the decking went on easily.
      I am not too concerned about the railings. I got fairly specific instructions from the building inspector on that (he gave me the common options). It will be 42" balusters screwed with 2 3" screws into the header all around. 4" gap between balusters. Then 2 more 3" screws into the guard, onto which the railing is fastened. All of this in cedar.
      The inspector claims that this is stronger that the other common option of 4x4 posts at 4' intervals with balusters fastened to a top and bottom rail. Posts to be fastened between joists as you indicated in your post.
      Whether it is stronger or not is a moot point for me. As long as it is strong enough.
      Tomorrow I finish my stairs...
      Thank-you for your help. I really appreciate it.
      1. Piffin | Sep 01, 2004 07:58am | #3
        that is a strong and fairly erasy way to do it - as long as the rim is well attached to the joists. I have ssen jobs where the ballusters were so attached, but the rim was only fastened into the joists with a couple of 16d nails end nailed in each with no hanger hardware and no toenails. The thing falls rtight off because the rail acts as a lever to pry the rim off.
        The other thing I would recommend for you doin git this way is to pre-stain /seal he wood between that connection because it will tap water and be the first place for rot to begin.
        Sphere | Sep 01, 2004 03:54pm | #4
        Don't forget blocking between the outer joist and it's next inner one, this takes a lot of flex out of the railing connections, I use at least 1 block at each post location..esp. if the outer is not a double.
      3. FastEddie1 | Sep 03, 2004 07:15am | #5
        And you reaslize that a 4" gap is a not-to-exceed number.  You might want to fudge a little on the narrow side ... maybe plan on 3-3/4" gap.   One nice thing about using 4x4 posts every 8 feet or so for the railing ... you can set the balusters between the posts and adjust the spacing for a nice balanced look, and stay under 4".
        Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
Tools for Managing Home-Building Financials
Production manager Ian Schwandt explains how financial tools such as QuickBooks or Buildertrend can help companies track project costs for a healthy outcome.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
