Deck post spacing
rickchem | Posted in Construction Techniques on April 4, 2003 06:09am
Just wanted to double check before laying out a deck saturday – I’ve looked at the tables already.  14′ x 22′ deck, second story, 2×8 joists.  I plan on having two beams going across – one at 4′ from the house, one at 8- and having a 2 foot cantilever at all sides.  I’d like to go with three posts on each beam, having a 9ft unsupported span.  I was thinking a tripled up 2×12 beam would be way more than enough.  Maybe even a triple 2×10?  This is my first second story deck, and I want it *strong* (but not “clunky”)!
Oh yeah, and while I’m thinking- for any of you deck experts- do you put tar paper over the tops of built up beams for moisture protection, or leave as is?  I’m in the mid atlantic.
Thanks all!
  1. MojoMan | Apr 04, 2003 06:39pm | #1
    Is there some reason you can't attatch the deck to the house with a ledger and use just one beam?
    Al Mollitor, Sharon MA
    1. rickchem | Apr 05, 2003 05:13am | #5
      Yup - the house jogs out 2 ft in one section (1/3 of the length) as an overhang.  I'm leery to put a load on something that is already cantilevered (plus the code doesn't allow it, as I understand it).  I figured I would just continue the beam, which would permit me to use 2x8 joists rather than 2x10 for the 12 foot span I would have with only one beam.
  2. dustmonkee | Apr 04, 2003 07:32pm | #2
    Check out http://handymanusa.com/articles/tables.html   Good reference for post, beam and joist spacing.
    regards
    JDRHI | Apr 04, 2003 11:37pm | #3
    Maybe I`m doing the math wrong.....I`m assuming the 14' measurement is off the house. If the second beam is 8' off of house, you`ve got a 6' cantilever.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    1. rickchem | Apr 05, 2003 05:09am | #4
      My bad- should be another 8 ft- so a beam at 4 ft, and a beam at 12 feet from house . . .
    ProDek | Apr 05, 2003 08:28am | #6
    I'm in the land of 4x beams but if you have to use 2x's I would triple a 2x12 because if you are going to have a 2' cantilever on a 14'x24' deck your beams will  span 10' not 9'. (24'- 4'=20' divided by 2 = 10')
    Putting 15# felt on top of your tripled up 2 x12 will definitely help detour trapping water between the joists.
    Bob
    1. rickchem | Apr 06, 2003 11:44pm | #7
      I was hoping I would get a response from you!  This is my first "real" deck - and I want it done right, especially since I am doing it for a friend.  The deck is actually 16x22- looked at the site today, minus 2 ft here, add 2 ft there.  So 9ft spans . . . but I might still go with the triple 2x12.  What is your feeling on a beam with spacers in between?  I looked at a deck that was done by the man they were going to hire ("professional") that was roughly the same size, but used 2 2x12 with a 2x4 spacer for the two beams parallel to the house. . .is that even kosher??
      Thanks!
        ProDek | Apr 07, 2003 02:37am | #8
        A double 2x12 at 9' span should be plenty. Your "professional probably used 2x4 spacers because they were treated and much less expensive than treated 1/2" plywood spacers. Two 2x's and 1/2" plywood = 3 1/2" which gives you a beam that is easy to gusset while sitting on top of a post.
        If you don't have to span 10' and only span 9' you should be alright using this method.
        Bob
