For the railings was thinking of using 2×6 on top, 2×2’s for the rails, and 2×4 along the bottom. What is the max distance from post to post?
Apparently you have to have a grippable hand rail on stairs. If you are building with redwood what are your options? I have seen handrail on top of a flat 2×6, and also a handrail attached to existing rail construction with hardware, like on interior stairs at a wall. Both those options are unattractive.
On 2×12 ptdf stringers, what is the typical distance between them? For example a run of 6ft, and the stairs are 5′ wide. Using 2- 2×6 as treads on each tread.
Thx.
Greetings yo,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
The end move in politics is always to pick up a gun.
R. Buckminster Fuller
Don't neglect the strength of the railing. It's got withstand a 200 lb. sideload, and that kind of strength is difficult to acheive by simply bolting the posts in place. And, if you notch a 4x4 post, it almost never will take that load.
Expect some code changes on '07 reflecting this and ledger attachment. Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein (or maybe Mark Twain)
"Get off your dead #### and on your dying feet." Mom
"Everything not forbidden is compulsory." T.H. White, The Book of Merlin
Dang...can't notch 'em, can't bolt 'em........what exactly are we supposed to do?
Block the bejeebers out of 'em. Except the wood shrinks, and things loosen.
Simpson shear wall brackets to hold the rim joist to the joists, bolts and big square washeres to hold the posts to the rim.Andy
Typically I never go more than three feet between stringers. I also rarely use 2x material for treads. I like the look of 5/4 much more. And two 5/4 or 2x 6 is right.
I also use CCA for all my risers but I use 1x for those.
Baluster spacing is code related and around here its no more than 4" max of space between spindles.
On my deck posts I never go more than eight feet post to post and when I do go eight feet I always put a support block in the center under the bottom rail (assuming you're using bottom rails)in case someone decides to sit on it...grrrrrrr.
Typically I like six foot runs but its up to your own tastes.
Be well
andy
What is CCA? I'm taking it is something else besides the old pressure treated lumber or...
where are you finding CCA?
be Can't Cuite Adapt
The end move in politics is always to pick up a gun. R. Buckminster Fuller
Edited 11/19/2006 2:27 pm ET by rez
I donno...WETF they're calling it now a daze. The green wood. Pressure treated, water resistant, H20 buster...I donno I donno...stop being a pain in the azz...lol.
"This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Cheers, rez"
oh, you mean ACQ, the new pressure treated farty wood that lawyers are learning to love.
be two years
View ImageThe end move in politics is always to pick up a gun. R. Buckminster Fuller
yeh...tecos? We don't need no stinkin' tecos
Cheers, rez"
We're all going to have to learn to use timberframe technology fer making decks.The end move in politics is always to pick up a gun. R. Buckminster Fuller
engineered timbers though...ugh
Cheers, rez"
be a city slickerThe end move in politics is always to pick up a gun. R. Buckminster Fuller
I do not like to separate stair stringers more than 16"OC, but it depends whether you are housing the treads or cutting the stringers, and on how long the stair set is. A three step flight is wholly different than a fifteen tread setup
