The international code requires that handrails be grippable, no more using 2x4s or 2x6s. I don’t mind, I’m just curious if anyone has come up with any designs that they like the look of and don’t cost an arm and a leg?
Most folks just add a cheap fir indoor handrail to the guardrail. Exactly why this, that will rot in a few years, will pass while a PT 2x4 won't, points up some issues with building codes.
Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
"Get off your dead #### and on your dying feet." Mom
Well at least it's grippable until it rots.You can put a 2x4 vertically if you rout out a grip. That's the best solution I've come up with.
Interesting, we're on the 2002 IRC, and exterior hand rails can't be more than 3 1/2" in cross-sectional dimension...some clients have us screw a 2x4 on top of a whatever by 6" cap, then take it off after inspections<G> I need a dump truck, baby, to unload my head
What about copper pipe in about 1-1/2" or 2" diameter? Slip a dowel into it for support. I've also done the same with PVC pipe, but definitely less elegant!
Edited 7/7/2006 3:02 pm ET by Danno
Here's something with the grip plowed out. Might work. Table saw and roundover in a router.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
"Here's something with the grip plowed out. Might work. Table saw and roundover in a router."Yes that's legal here (NY) and about as good looking as anything I know. The copper pipe sounds pretty. How do you attach it?
I've bored the post and inserted galvanized emt into the hole. Used a stainless screw to "set" the pipe to the post. This runs post to post.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
