i am using a 2 inch wide decoretive rope type stone type on top of polished stone in a shower. My question is how do you cut an inside corner with this rope tile.
I know how to cope inside corners with wood moulding and i was wondering if its the same process?
any help is appreciated.
You do have a choice.
Either way, there's a grout or caulk joint, however thin.
Mitre or cope. You can cope it in carefully using a grinder and diamond blade or by using again carefully, a water saw. Either way if coping I'd still start with one pc. mitered, then safely grind away the scrap.
