Besides cost, any comments on the differences between a basement floor system using Delta-FL covered with tongue & groove plywood/OSB vs. using DriCore or Sub-Flor panels?
If I use the Delta-FL, is there a significant difference between OSB or plywood?
Thanks for any help.
Paul
Greetings G,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
when in doubt add garlic
Having done both, I'd recommend the Delta-FL with plywood. Cheaper, faster. If your concrete floor is really flat, you won't notice much difference in the final product. If it rolls, you can either try to shim everything up to level or go with it. In that case, the plywood will be screwed to the concrete, will conform to the floor, and still feel solid. The Dri-core will be bouncy.
bumpwhen in doubt add garlic
