Design of Circuit breaker Panels#*#**
I wonder if they will ever be designed with a removeable panel just below the panel box to allow you to get to the romex cable holding connectors, so you dont have to cut sheet rock to get at them, like to increase the size of a wire or run a new wire.
Is it like this all over the world?????
What a great idea!
You can buy these at the sheetrock places. Metal access doors.
They even come in the same colour as the electrical panels.
You can buy access panels or build your own.
For example, I have a sub panel in my laundry room with a removable panel over top of it which provides access from the electrical panel all the way to the top plate. Remove four trim screws and I'm in!
Jim
Changing wire? That's what they make conduit for.
not in residences in south carolina.
