About a year ago I used a Dialectric Union on both copper pipes when I installed a new water heater.
I looked at it today and I see corrosion on the copper fitting next to the union.
Did I do something wrong?
Did you wipe the joint after you soldered it? Excess flux will cause corrision.
It is acid after all.
I don't think I cleaned it up like I should have. I was probably hurrying.Thank you.
Must be your own house right? I rush through home project too. Ahhh i'll do it right later, it'll hold for now. :>)
If you used a water soluable flux, they corrode faster than the non water soluable ones do.
& generally it will be green with a white exterior after a long period of time.
If you're really worried you can do an ohm check across the fitting.
