Dimmer installed in bathroom = humming
lokkie | Posted in General Discussion on January 27, 2008 10:39am
Hey Everyone,
I recently replaced a standard light switch with a Lutron Dimmer for the lights in the bathroom.  Now, they have a very very very low hum to them when at full strength but as I dim the lights, the hum gets louder and louder.  The Dimmer isn’t a 3-way if it matters any.
It’s a standard bathroom type fixture (3 incandescent lights) not halogen etc.
Any idea of what would cause the switch to cause a hum to come from the light?
Thanks,
Paul
  1. semar | Jan 28, 2008 12:58am | #1
    I am not an electrician but I think it has to do with the grounding. try it on a different location
    Edited 1/27/2008 4:59 pm ET by semar
  2. andyfew322 | Jan 28, 2008 01:46am | #2
    yeah,  Ibelive all dimmers do that. at least all of mine. Is the humming coming from the bulbs?
    "It is like hitting yourself in the head with a hammer: it feels so good when you stop"
  3. peteduffy | Jan 28, 2008 02:09am | #3
    Replace the bulbs with ones with thicker filaments.  Call customer service, and they'll let you know what kind to get.
    Had the same problem in a dining room.  New bulbs solved it.  The humming is caused by the filaments vibrating.
    Pete Duffy, Handyman
    1. lokkie | Jan 28, 2008 02:30am | #4
      Thanks Guys.
      I'll double check the ground and get some thicker filament bulbs.
      Last i checked, i didn't notice bulbs manufacturers advertising bulb filament thickness. How does one go about determining a quality incandescent from an inferior one?
      Paul
      1. DanH | Jan 28, 2008 03:23am | #6
        The ground would have nothing to do with it. It's the filaments.
        1. semar | Jan 28, 2008 04:08am | #8
          thanks
      2. bubbajames | Jan 28, 2008 03:43am | #7
        I believe rough service bulbs might fit the bill. The kind used in mechanic's droplights.
  4. DanH | Jan 28, 2008 03:22am | #5
    If the hum is coming from the light bulb then it's due to the design of the filament in the light. A different brand or style will generally be different (though not necessarily better).
    (Or it could be that the light bulb simply doesn't know the words.)
    1. lokkie | Jan 28, 2008 11:17am | #10
      LOL... doesn't know the words...
  5. Stash | Jan 28, 2008 04:33am | #9
    I'm not an electrician, but mebbee it just doesn't know the words.
    Steve
Fast, Accurate Wall Framing
