Direct injection engines
FastEddie | Posted in General Discussion on January 15, 2009 08:23am
Article in yesterday WSJ about significantly increased fuel economy in gasoline engines that use direct fuel injection.  I thought todays fuel-injected engines already did that.
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. user-64511 | Jan 15, 2009 08:29pm | #1
    Not exactly, most of today's engines use 'port"fuel injection where the fuel is injected ahead of the intake valve in the intake manifold just before the cylinder head. A ' direct injection engine has the fuel injected directly into the combustion chamber.
    Bruce
    1. DanH | Jan 15, 2009 08:39pm | #2
      There are actually several different variations of non-direct injection. Some have a single injector in the "throttle body", while others have multiple injectors in the intake manifold, though not always one per cylinder.Direct injection is how a diesel engine works, of course. It requires high pressure (15000 PSI), whereas the others just require 100-200 PSI or so.With direct injection gas engines they can play games with injection timing (since ignition is via spark, not compression), injecting during the intake stroke for a rich mixture or injecting during the compression stroke for a lean mixture, reducing emissions and improving efficiency.http://en.wikipedia.org/wiki/Gasoline_direct_injection
        McDesign | Jan 15, 2009 10:07pm | #3
        You can also start the car without a starter!
        1. DanH | Jan 16, 2009 12:37am | #4
          I suppose. Just figure out what the crank position is and inject fuel into the cylinder that maybe 1/3 of the way down on the power stroke, then fire the spark plug. Kind of a built-in Coffman starter.
            McDesign | Jan 16, 2009 12:43am | #5
            Sort of - actually, they squirt and fire a cylinder that's coming up on its compression stroke, which spins the crank a ~ half turn backwards, compressing another cylinder which is then fired to kick the engine in the correct direction, and then the normal firing is initiated.
            Cool!
