Does anyone know if there’s any way to dissolve dried hot mud residue from out of a banjo? Acetone maybe?
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
no solvent will disolve it. acid perhaps. soak it for a day and scrape.
[email protected]
Acid..you mean muratic acid?
Water is a solvent (although a very mild one) and it does work, but it takes a verrry lonnng time.
-Don
I got this from the msds for durabond 45. Looks like acid would eat it off because of the limestone and plaster of paris. Vinyl bonder may need to be be attacked with something else, but try an acid and see what happens.
MATERIAL WT% TLV (mg/m3) PEL( mg/m3) CAS NUMBER
Plaster of Paris (CaSO4•½H2O) 60-100 10 15(T)/5(R) 26499-65-0
Limestone 10-30 10 15(T)/5(R) 1317-65-3
Mica 10-30 3(R) 20 mppcf 12001-26-2
Attapulgite 1-5 (NE) (NE) 12174-11-7
Vinyl Alcohol Polymer 1-5 (NE) (NE) 9002-89-5
I should have said chemical solvent.
I know, you're gonna tell me that water has a chemical composition!!
Breaktimers!!![email protected]
Thanks all. I guess if you decide to put hot mud in a banjo, you better be paying attention to how it's setting up.
Water. Soak, scape. Water, soak, soak, scrape. Repeat. Repeat. Taps from the outside will sometimes break large chunks out, but may dent steel.
Mike
Just a thought: white vinegar or CLR, Bam, lime away. Might be worth a try and should not hurt anything.
You screwed up there . <G>
As Eric mentions Ive never known any solvent .
Any sanding method will work. Even a dremel with a wire brush, stone wheels , and such. Hand sanding and machine will work to on areas that are accessible . Down to screw drivers and picks , scrapers that are sharpened. Its not like concrete . Morter its close if its cured.
Acid might work but Ive never tried it .
Depending on the banjo brand you should be able to handle the job as described above. I made a 90 degree angle hook one time from a concrete nail to clean the feed mechanism from a banjo but another brand comes apart for cleaning which is easiar.
Tim
I would go with a mild acid solution, such as CLR or one of its kin. It'll have to soak a bit, and then brushing/scraping will be required.
Next time, don't play music while you're mudding. :)
happy?
