I am a college student in Washington and I am roofing my moms home. The larger sum of the house is cathedral ceilings constructed of 24″ O.C. 2×12’s. To my knowledge, the only way to properly vent such a roof (without using a hundred cap vents) is to use continuous ridge and soffit venting with baffles. Seems simple enough, but in this months issue of Fine Home Building (Sec: Wackiest Fixes) Joe Henessy wrote that ridge venting always leaks. Living in the most waterlogged part of the country, this concerns me! I don’t know how to protect against this, or get around it while maintaining proper ventilation. If you professional guys have any insight, it would be much appreciated
Thanks, Joe
Only the ones that Joe H. installs :).
Some models may leak and others usually don't. Good designs allow for a certain amount of wind driven rain, but by the same token, that kind of wind may take off your shingles as well.
Gabe
*we only use shingle over ridge vent that has baffles..our favorite brand is Shingle Vent II.. and they don't leak.. check the archives for Airvent.com..
*I haven't used it myself, but I'm hearing good things about that foam ridge vent(shingle over).Any good/bad results??
*Absolutly not, never on a sunny day.
*I've been using EverFlow and Ridgline cap over ridge vents for 10 yrs. now, no problems, hundreds of roofs. Before that I used Leigh aluminum ridge vents and had quite a few problems with leaks.John
I agree with Mike. Go to Airvent.com they will explain how all ridge vent is not created equal.
I've never had any problems with this product.
What I like is they incorporate a baffle, to block wind driven rain , which may be blown uphill towards the ridge during one of them rainstorms where the rain is going horizontal.
But remember , mother nature, if determined enough will have his/her way on any house.
I am a college student in Washington and I am roofing my moms home. The larger sum of the house is cathedral ceilings constructed of 24" O.C. 2x12's. To my knowledge, the only way to properly vent such a roof (without using a hundred cap vents) is to use continuous ridge and soffit venting with baffles. Seems simple enough, but in this months issue of Fine Home Building (Sec: Wackiest Fixes) Joe Henessy wrote that ridge venting always leaks. Living in the most waterlogged part of the country, this concerns me! I don't know how to protect against this, or get around it while maintaining proper ventilation. If you professional guys have any insight, it would be much appreciated
Thanks, Joe
