When you make your pan for a door on a concrete slab, what do you use to adhere it to the slab (assume the walls are wood framed)?
What gauge metal do you prefer?
Have you ever then used a flashing such as Dupont’s Straight Flash accross the pan and up the sides?
Or is three beads of silicone under the sill good enough for you?
WWPD
Silicone to the slab, but gravity does most of the work.
I usually use standard coil stock aluminum.
Buy Sam a drink, and get his dog one too.
