A few years ago I purchased a #2 driver bit tip that was designed to install the screws on door knobs with out damaging the finish on the knob. It was about three inches long, with a thin tapered shank (about 3/16″) that had a plastic or vinyl protective sleeve along its length where the bit usually contacts the door knob. I have since moved and in the process have also lost the bit. I am trying to locate a manufacturer of this type of bit, but I have had no luck. Can someone tell me where I might find such a beast – online?
The recipe for linoleum hasn't changed much in nearly 170 years, yet it's still one of the greenest floors money can buy.
A few years ago I purchased a #2 driver bit tip that was designed to install the screws on door knobs with out damaging the finish on the knob. It was about three inches long, with a thin tapered shank (about 3/16") that had a plastic or vinyl protective sleeve along its length where the bit usually contacts the door knob. I have since moved and in the process have also lost the bit. I am trying to locate a manufacturer of this type of bit, but I have had no luck. Can someone tell me where I might find such a beast - online?
