I’m building a new front door on my house. Is it proper to mortise for the lockset first, before beveling? It seems easier to do it this way, instead of routing a mortise from an edge that isn’t perpendicular to the mortise. It would seem easier to set the mortise for the lockset’s flange a little deep, so that beveling later will bring the leading edge back to flush with the lockset flange again.
I practiced beveling first and then mortising on a test piece, and it was rough work getting the mortise straight (ended up drilling/chiseling) and then also getting the flange mortise perpendicular to the mortise on a beveled edge. I’m suspecting I should mortise first, then bevel.
Am I on the right track here?
Thanks,
Rob
bevel first, then cut the mortises for the hinges
caulking is not a piece of trim
